N130WN
What are others using for torque values on their trutrak AP's? IE, my DF200VS model has torque values from 0-250. I think other models have just 1-12.
Trutrak torque
For your initial set up suggest you use the following:
Aeleron: 1-3 for normal flying, add more as required if you are in heavy turbulance. The RV8 has a very responsive aeleron with a light touch.
Elevator: 3-6 for normal flying, more with turbulance. The elevator on the RV8 has a heavier control requirement than the aeleron, thus more torque is required. Also, load (heavy passenger, and baggage) will require more.
Note: the activity setting for the RV8 is usually set low for normal flying, except if you encounter heavy turbulance, increase it as needed.
Dick Martin
RV8 N233M
Trutrak test pilot
Trutrak torque
Aeleron: low for normal flying, add more as required if you are in heavy turbulance. The RV8 has a very responsive aeleron with a light touch.
Elevator:low to medium for normal flying, more with turbulance. The elevator on the RV8 has a heavier control requirement than the aeleron, thus more torque is required. Also, load (heavy passenger, and baggage) will require more.
Dick Martin
RV8 N233M
Trutrak test pilot
