jjconstant
I've been trying to get the settings correct for my TruTrak 2 axis digiflight system. With the auto pilot engaged and selecting a heading on the autopilot head, the plane banks correctly, starts turning and then starts bobbing up and down in pitch, which diverges until I turn it off.
I experimented with different settings in torque, sensitivity and static lag. I then thought to try it with my alternate static source open (to cockpit). It became rock solid in the turn.
I called Tru Trak and explained all this and the first thing they asked was if my static source was on the pitot tube. Why, yes it was! They then stated that they felt that kind should be outlawed and while they may have worked with the old steam gauges with bellows, modern stuff was far too sensitive and that there were actually pressure pulses beneath the wing causing the pitch excursions in the auto pilot. They recommended using the standard Vans location and ports.
Between this and the major fussing I had to do to get my airspeed to read correctly with the current static source on the pitot tube, I'm finally ready to concede defeat and put the static source where Vans says to.
Education and Recreation!![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Jeremy Constant
RV7A 100hrs
Jeremy Constant
RV7A 100hrs
