Xkuzme1
I read some thread on another forum that Trutrak and GRT Servos are compatible and can be installed on similar equipment.
Can anyone confirm or deny?
X
I can confirm that they will fit in the same mount, and use the same control hardware as I pre-wired and installed mounts for trutrak but 8 years later ended up installing grt servos. Perfect fit, but now have extra wiring as grt uses fewer.
X
They share the same physical mounting dimensions. However, they are not electrically compatible and cannot be used on the others control system. I do not know if they share similar torque specs.
Larry
