Louise Hose
For those of you that followed the saga of Mikey's panel renovation (http://www.vansairforce.com/community/showthread.php?t=24139&highlight=Mikey), here's the most recent panel event.
Flying on Sunday, I noted that my oil pressure on my Dynon 180 was fluctuating a bit soon after take-off. It was in the normal range but bumping up and down about 10 units. It settled down a few minutes later and I managed to forget about it.
However, taking off for my commute Monday, I noted that the oil pressure was pegged in the red immediately after take-off, then fluctuating wildly.
All other readings (and sounds) were normal. The pressure reading soon dropped into the normal range and quit fluctuating by the time I landed. But, the problem now had my attention.
Paul drove over to our local Auto Zone Aircraft Supply store and purchased a $20 mechanical oil pressure gauge. We hooked it to the engine at the site where the annunciator connector normally sit and fired up the engine. As suspected (and hoped), the mechanical gauge was showing normal readings while the Dynon meter was pegged in the red (fluctuating up to 100 psi) when the engine was run up. At idle, both read about the same pressure. Diagnosis? A faulty oil pressure sending unit (transducer).
Before buttoning Mikey back up, we put the annunciator lead back on and also polished up the connector to the lead going to the Dynon. In discussing my problem with Larry Pardue, he mentioned once having fluctuating low oil pressure readings caused by corrosion at a sensor connector so we figured a little preventive maintenance would be wise.
I'll be calling Dynon once they open today and hope to have this problem fixed ASAP. But, at least I know it's a false reading and can keep him in the air.
