Lando143
I'm New Here
Gentlemen,
I am looking for advice on how to proceed with a rough running O-320 (400SMOH) on my RV-6. Here are the symptoms:
1. During engine warm-up in the hold-short RPM=800
2. After oil was coming up to temp (80 degrees), engine started running rough
3. I assumed foul plugs and waited til oil temp hit 100 degrees to accomplish mag check and clear plug at high RPM/lean mixture.
4. As I pushed throttle up past 1200 RPM it was obvious to me I had bigger problems than a fouled plug because of the significant vibrations associated with the additional power.
5. CHT's were as follows: #1-260, #2-280, #3-275, #4-135. yes 135 degrees.
6. Compression check on #4 revealed 76/80 with a hissing sound of air escape.
7. Air was escaping out of the oil breather line I have clamped to Left Stack for burn off.
8. I plugged the breather line with my thumb and all hissing stopped.
My conclusion thus far is that I have ring issues. No sign of metal upon magnetic sweep of cylinder.
What advise would you guys (that are clearly smarter than me) have regarding pulling the cylinder vs more inspection/testing? Borescope worth the trouble?
I eagerly await response form the engine gurus!
Thanks All,
Hank
Thanks All,
Hank
