double check squelch
I had a similar problem and someone on the forum suggested to check the squelch knob. I had inadvertantly turned it too far up. You might double check to see if something similar happened to you also. It sure was an easy fix for me, hope that's your problem, cause I've been impressed with what I've heard about Halo and have plans to buy one. Be sure to post how you fix the problem.
