Non RV installation.
Headset without in-line volume control. Problem: Audio panel will adjust all volumes except alerts. Alerts are way too loud (hearing damage too loud). If the headset had an in-line volume control the solution would be to turn down the in-line volume and turn up the radios, intercom, etc. This reduces the alert sounds.
Is an in-line volume simply a series wired potentiometer? If I just wanted to cut the volume a fixed amount could I simply insert a resistor in series or parallel? What watt 1/4 ? How many ohms?
