N546RV
This may be a simple question, but I'm wondering if anyone else found it necessary to remove some material from a gear box weldment. I've been assembling my gear towers today, and I'm at the point of bolting the box weldment into the right gear tower, but I can't get the washer to sit flat on one of the middle bolts. It appears that the weld in this spot was just built up a bit too much and impinges on the area around the bolt hole.
I figure I'll just file this area down until the washer fits, then shoot some touch-up primer to cover the bare metal - but I wanted to check and see if anyone else had run into this first.
Edit: Went back out to match drill and check the left box weldment, and it has the same problem. In both cases the issue is on the side of the weldment towards the rear of the aircraft. Forward bolt holes are fine for both pieces.
Photo: (click for fullsize)
![](/community/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FmzufdXpl.jpg&hash=9b840daceac2ba49d73256ac7fac6e56)
