I'll already extended the square hole in F-419 deck back 5/16" (from 3 7/8" as given on dwg 30) to 4 3/16" and still only have 22 degree elevator up travel ( think I started with 17 or 18). The tip of the elevator horn is about to hit F-412 (the rearmost bulkhead).
Do I just keep trimming the hole in F-419 further back and start trimming the rear tip of the horn until I get to the 25 degree minimum up travel?
I'm beginning to worry about the amount of trimming needed.
Finn
Finn
