I go with 1/2". Some engines really dance around on start up!
In your case, that would be 1/2" from the top plenum cover to the cowl.
So 5/8" ?
1/2" Wow! That's not dancing. That's some serious boogie!
I've cut them @ 3/8" so far. Easy fix. Right now, I'm in Frankensnorkel He77!
Remember the side baffle panels should be a bit shorter because your glass plenum cover will have some thickness too.
