LUKLA
Active Member
RV 12 with dynon HDX. Elevator trim tab indicator (green indicator in HDX) disappeared??
It was there and working fine so far. now all of a sudden its gone.
Any suggestion how to get it back !!!
It seems to be a pretty common problem. Ours was indicating erratically for a while. I finally tracked it down to a slightly loose pin in the connector back under the tail fairing. Now it's rock solid.
