I'm wondering if anyone else has any experience with this problem on the RC Allen Trim servo....
I seem to have a "Dead spot" when I am trying to trim nose down. I can hear the relay click, but I get no trim motion, I can trim up a little bit, and then it will trim down again. It will work fine for several more cycles, and then appear to be in a dead spot again. Nose up, then the nose down works again. Sometimes it takes two blips of nose up to get it to work nose down. A very strange problem...I suppose it COULD be a contact problem in the relay as well, but I'm not sure...
Just curious if anyone else has seen this, and if there is a fix other than a new servo.
Paul
Paul
