Greg Arehart
Not sure where to post this but....
I am thinking about instruments and looking at transponder dimensions, all except the Garmin do not appear to fit in the space behind the panel (building 9A). As I measure it, the available space (depth) is a bit over 8.5 inches, and most transponders are in the 10-inch range. What, if anything, are people doing for transponder mounting if you are using other than the Garmin? I have been considering whether to cut a hole (lighter is better....) in the bulkhead panel behind the main panel....
thanks,
greg
thanks,
greg
