Tall_Order
Patron
Getting ready to bond the tipover canopy to its fiberglass support structure. Then the canopy edges get filleted to blend with the canopy skirt. I am a little worried that the transition between the flox and acrylic won't be neat and sharp- is there a low profile P- shaped rubber or plastic strip that anyone can recommend to bond into the edge?
(Same idea as tile edge trim on your home renovation)
Showplanes tip over? All the canopy edges are encapsulated under two plies of fabric. There is no flox edge showing anywhere.
Haha using a bit of flox or micro on top to get the transition radius just right ;)
