rjcthree
My ADS-B setup is an Aera 660 gps, GDL 39 in, and a GDL 82 out connected to a GTX 327. Reports are excellent, it works. The distracting thing is that the 660 will show traffic tracks that are clearly old (4+ hours - and I've seen a track I know to be >12 hours old). The tracks overlay the map, especially in entry and exit areas of my home airport, which isn't that busy, but is under class B airspace. I'd like to figure out a way to eliminate them or at least shorten the life of past traffic tracks. I spent about 90 minutes with the 660 manual and working through menus, and I don't see anything there to adjust. I have not started in on the -39 or-82 yet. Has anyone else seen this and found a solution or a setting? Most everything is at factory settings currently. Thanks.
