I'm not sure how North Up would even work on Synthetic Vision Bob - by it's very nature it is supposed to be identical to what you would see if you look out your windshield (which better be Track!)
Paul,
I probably didn't state that well, and I may be using SV incorrectly to describe both the EFIS/ADI
and the moving map, in a two screen, or split screen SV system.
On the EFIS/ADI, as you said, the view has to be straight ahead (well maybe it doesn't have to be, but it would be pretty useless if it wasn't...well unless you wanted to look off to the side and see if there was an escape canyon...but I badly digress!
On the plan view (overhead) map next to the SV EFIS/ADI, I would think the presentation would be track up as well, so that straight ahead on both screens is a match. Thus, an airport ahead on the moving map is where the SV runway on the EFIS/ADI appears...ahead. I would think looking at a runway (call it RWY 27) ahead on the EFIS/ADI, next to a map that shows the airplane moving right to left on a N-up map towards the same airport would be really confusing. But I'm a track up guy, and it may work for those that like N-up, and that's AOK.
I kind of liken the N-up display to the map you see as a passenger in a 777 or Gulfstream, that shows the progress of the flight. Great for overall SA, but less workable (for me anyway, having bought into the misguided man club
) when avoiding wx/terrain/obstacles, or for pointing the airplane at a waypoint or airport. Now, I'm not saying that those using N-up are like pax in the back...really I'm not
(and that really is tongue in cheek, just foolin'...its like a mayo vs miracle whip thing...whatever works!)
Like you said Paul, it is interesting to see all the responses, and none are wrong, of course! Good to understand that different brains work differently if you're training someone on the use of new gear.
And Warren, its TMI, but I blew up your guess right out of the door...though Scott does have a point...it that right side in a track up or N-up setting?
Sadly, my unabashed attempt at getting a ride in an SV airplane has met with utter failure!
Bob
