Someone once reported here that a Cessna 150 tow bar works just fine. I do hope so. Music to my ears, I kept the towbar when I recently sold my 150!N788RV said:I'm looking for recommendations on a good tow bar that will work well with an RV-8. I noticed a friend of mine had to do some modifications to his (made the socket deeper that fits over the tail wheel bolt).
A buddy gave me a (small) Cessna towbar and it works perfectly. Not sure if it's for a -150/152, but probably is. Would work slightly better than perfect if the wheel bolt was actually stud that protruded each side about 1/2". But it's pretty low on my list of improvement projects.Rick6a said:Someone once reported here that a Cessna 150 tow bar works just fine. I do hope so. Music to my ears, I kept the towbar when I recently sold my 150!
Bryan,Low Pass said:A buddy gave me a (small) Cessna towbar and it works perfectly. Not sure if it's for a -150/152, but probably is. Would work slightly better than perfect if the wheel bolt was actually stud that protruded each side about 1/2". But it's pretty low on my list of improvement projects.
Thanks for the info. In a similar vein, was just thinking I could probably easily pick up a Grade 8 bolt that was ~1/2" longer and use washers on the head side to provide a little more projection/engagement.N941WR said:Bryan,
When I bought my Doug Bell Tail Wheel, he gave me some extra bushings and a longer bolt than normal. This allows the Cessna towbar to fit over the longer stud, as you describe.
I have to hand it to Doug Bell, Jr & Sr, they sure know what they are doing!
I'm sure a Grade 8 bolt will work. One advantage to the AN6-46 was it came drilled. I figure the cotter pin is cheep insurance at $2.98.Low Pass said:Thanks for the info. In a similar vein, was just thinking I could probably easily pick up a Grade 8 bolt that was ~1/2" longer and use washers on the head side to provide a little more projection/engagement.
First I used a smaller cotter pin, and that worked fine.John_RV4 said:Just tried out my Bogi bar last night and it won't fit over the cotter pin. We all use the same axle right ? Did anyone else need to make some mods to get it to work ?
