C-J
Active Member
Has any one mounted Tosten Aircraft Grips in their RV 14 Yet? We got ours in today and looking at the bend in the stick and using the Tosten bushing, it looks like I can only remove about 3.5" from the stick where removing 4.5" would be best and keep the grip height relatively the same. Using 3.5" would make the actual stick grip where your hand sits about 1"higher. The grip end would still fall below and 2" aft the panel itself, so I'm not worried about the interference aspect.
Any experience here is appreciated. Thx Carl
