Adam Oke
I'm in the market for a decent torque wrench for my build. I just need a wrench to get me through the tail/wings/fuse for now. I can pick up another wrench and/or borrow for the engine/prop. As far as I can figure, it should be a 1/4" and in the 20-150 inch pound range. Most of my tools that I use often are Sioux, Klein, Snap-On, Mastercraft etc, so I'm not afraid of buying quality on the tools I use often. With the amount of times I will use it, is it necessary to spend the big bucks on a good torque wrench? Is a wrench from Princess Auto being too cheap in this area? I can also make a run over the boarder and pick up a Harbor Freight wrench as well. The common mid-range wrench that I read around here, appears to be the CDI Wrenches, which are a Snap-On brand.
The more I get reading, the more I wonder if +/-1 to 4% is really necessary. I am building an airplane, not a watch.
Here are some suggested torque values:
AN3 20 to 25 Inch Pounds -- Average 23 = -15/+9% Average Torque Value Tolerance
AN4 50 to 70 Inch Pounds -- Average 60 = -20/+16% Average Torque Value Tolerance
AN5 100 to 140 Inch Pounds -- Average 120 = -20/+16% Average Torque Value Tolerance
AN6 160 to 190 Inch Pounds -- Average 175 = -9/+8% Average Torque Value Tolerance
AN7 450 to 500 Inch Pounds -- Average 475 = -5/+5% Average Torque Value Tolerance
AN8 480 to 690 Inch Pounds -- Average 585 = -22/+18% Average Torque Value Tolerance
AN9 800 to 1000 Inch Pounds -- Average 900 = -13/+11% Average Torque Value Tolerance
AN10 1100 to 1300 Inch Pounds -- Average 1200 = -9/+8% Average Torque Value Tolerance
AN12 2300 to 2500 Inch Pounds -- Average 2400 = -4/+4% Average Torque Value Tolerance
The average torque value tolerances are roughly calculated and rounded. I haven't read too much into the plans beyond the tail, but my understanding is the majority of bolts on this project (tail, wings, fuse) are AN3 and AN4. These have quite a tolerance range. I am wondering if it is really neccessary to buy a wrench that is +/-1% when the tolerance range is about +/-15% for most of the work!
Obviously on critical parts (ie Prop) I will use/rent/borrow an accurate, high end, calibrated wrench. For these parts with such a large range of tolerances, I am starting to think that the Princess Auto torque wrench will suffice. Even if it seizes up, it has a lifetime warranty and I can go swap it for a new one. Heck, if I want to "re-calibrate" every so often -- I can swap it for a new one!
What kind of click-type 1/4" wrench in the 20-150 inch pound range do you suggest?
