Yep, same part. You will see this in the store occasionally. If they gave you the dimensions- you would go make it yourself.
Oil
Others have found oil hose of same diameter. Apparently the Vans stuff in years past was not oil proof and dies after a decade or so.
I’ll let you if my Vans original ever dies.
There are two parts to this, one is the rubber hose that should be oil resistant (I source mine from AS) and the other part is the aluminum tubing that bends just over your exhaust. It also has a swaged end to match the diameter of rubber hose used. That’s what I bought from vans.
