Types cuts
I have a 3/4 wide blade on my saw, so it is used for straight cuts which is about 90% of the time. You can buy skinny blades down to 1/4" for real tight radius cuts. Blades are not that expensive and it only takes about 3 minutes to change the blade on mine. Hope this helps. ADEN
