RV7Guy
I found this on one the helicopter forums I'm on. Very funny. Add other definitions if you have them.
TOOLS EXPLAINED:
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. It will also remove fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh ****"
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until they melt.
SKILL SAW: A portable cutting tool used to make studs too short to use in your remodeling job.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
****-IT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMM-IT" at the top of your lungs. It is also, most often, the next tool that you will need to finish your current project.
Other workshop definitions
MURPHYS LAW OF INANIMATE REPRODUCTION
If you take something apart and put it back together again enough times you end up with two of them
MAGIC WORDS
Some jobs require magic words
MAGIC WORDS 2
Children or wives are within ear shot when magic words are required
THE LAW OF HORIZONTAL SURFACES
Any horizontal surface becomes a table within two hours.
St. LUCAS'S LAW OF ELECTRICAL CONDUCTANCE
Smoke must not escape for this law to be operative
There was a bunch of others, but I don't remember them now.
Joe Hine
RV4 C-FYTQ
Fredericton N.B.
A couple more...
PRY BAR - is also known as a high speed knuckle exfoliator
CHERRY PICKER (Engine Hoist) - A tool used to test the tensile strength of whatever it is that you forgot to disconnect.
And Lucas, to his credit, did invent the two position headlamp switch - Flicker and Dim
This is very true!
After being with Texas Instruments for over 40 years, I can assure you that each circuit built contains a pre-calibrated amount of "magic smoke". If you EVER let this smoke out, the circuit will no longer function.
AVERY HAND SQUEEZER - a tool which uses special (usually #30) very short stubby pieces of metal to give you workout you will feel in your muscles for at least three days. A good substitute for Pilates they should advertise on TV.
Here are a couple I just made up. :)
BUCKING BAR - A solid peice of metal used to break chips of concrete off of the floor when dropped.
DIE GRINDER - Used for making squiggly line designs starting at and leading away from a 1" or larger hole.
SAFETY GLASSES - Primarily used when cutting something or using a high speed dremel with a cutting disc. Worn to deflect peices of metal or an incenerated cutting disc away from your eyes and into your mouth (which is probably open at the time of inceneration.)
PROSEAL - Designed for sealing, although usually is found on tools, workbench, and the bottom of your shoes and throughout the carpet in your house.
BUCKING BAR - tool also used in very rare special cases to mark the location of an antenna if dropped right.
Somebody posted that couple years ago. Was it Scott Card?
Benchtop belt sander - A device for demonstating friction heating and the thermal conductivity of aluminum.
Buffer - A device that magically senses the last pass on a mirror polished part and launches it into the machine base, imparting a large gouge in the aforementioned part.
Safety wire cutter - A device for demonstrating Chinese acupuncture.
Lucas Jokes
A couple more...
snipped
For those of you who have owned or worked on British vehicles (with Lucas Electric systems)
Why do the English drink warm beer?
They own Lucas refrigerators
Have you heard about the new Lucas 3 position switch?
Dim/Flicker/Off
Why are there no skyscrapers in London?
Would you ride in a Lucas elevator?
Hear about the new Lucas vacuum cleaner?
It's the only thing they make that doesn't suck!
And lastly..... Joseph Lucas invented darkness!
Ever wonder why British cars are so hard to push?
They are made of that rare alloy, Britainium. It's twice as heavy as lead, but only half as strong.
