LettersFromFlyoverCountry
The answer is:
It's the best crimping tool I've found.
go.
go.
The ones Stein includes in their Master Kit seems to work just fine. It doesn't do anything bigger than 10 or 12 AWG however, so you'll need to have your big wires crimped or soldered with something else.The answer is:
go.
You need 4, and you can get them all here:because my next question is how MANY crimpers do people need?
the ratcheting crimper Stein sells as part of the master kit includes dies for all the pidg terminals 12-22 i think and then also includes dies for the coaxial cables. The dies swap in and out real fast.Run of the mill 14-22 awg pidg-type crimping. One quesiton I have is whether I should buy a kind that you can swap out the heads (or whateve ryou would call it on) or a separate pair for each type.
But the question of what type is a good one because my next question is how MANY crimpers do people need?
