I’ve just rigged my VS and HS and all is good except for the elevator. I have 26.2 degrees of elevator down which is more than the 25 degrees max.
I used my digital level and zero’d it while the elevators were clamped in neutral, then removed the clamps and at full down deflection it goes to 26.2 degrees.
The elevator horns hit both up and down stops correctly and nothing is interfering.
Up deflection is 26.4 degrees which is less than the 30 max so that’s fine.
It looks like I need to add 1/16 to the down stop but of course that’s not going to be easy at all.
Any suggestions on how to fix?
