My 6A has almost a year on it now (first flight 12/12/09) and has had very few minor squawks. Total time is now 104 hrs. The start solenoid switch is an OFF-(ON) toggle switch with a flip up cover. I like this arrangement and have seen it in other aircraft, in contrast to the push button starter switch. The only issue is the switch is wearing out- when starting, you have to hold the switch at its extreme and then it takes a couple of moments before the starter actually begins to turn. The switch doesn't have the crisp action it once had. Does anyone know of an issue using a toggle switch for this purpose? Looking for some experience from the electrical gurus here! Otherwise, I'll just order a replacement and invest the 5 minutes it will take to "switch" out.
thanks for the help
thanks for the help
