aeroaddict
I'm still on track to start the RV build journey. Recently bought a hanger, it is insulated (walls and ceiling), and has a heater. The door is a Schweiss bi-fold and is not insulated. The door faces north and the area has the four seasons with cold temps in the winter and hot temps in the summer.
It seems a little useless to not have an insulated door. With the current HOT weather in the west, I can feel some heat coming off the door.
So my questions are; should I insulate the door and if so, how would you do that? I looked at the rigid insulation foam boards and the R value is not that great ~ 4 to 5 for one inch thick.
