I'm a long way from flying, but as always, thinking ahead...
For storing and operating my plane, I have a dilemna about which airport to choose. 10 min from my house is Ottawa Intl. They charge expensive landing fees, and forget about trying to rent a hangar there. But for less than $100/mo I can get tie-down there. Or I can drive 40 min away and rent hangar space at Carp airport, which is smaller and won't have the landing fees. Hangar space should be available there, and it will probably cost more than the tie-down at Ottawa Intl (CYOW).
The flight school and club at CYOW park all their planes outside. The only obvious sign of abuse is that the canopies on the aircraft are all scratched to **** (really obvious in bright sunlight). So I'm left debating a few questions:
1) assuming we don't get a tornado or hurricaine, is hangering really mostly a feel-good thing? Is there really any good reason why a plane shouldn't be left outside? In Ottawa, the winters get REALLY COLD, so I'd probably need an engine pre-heater and de-icing fluid handy.
2) Is a canopy cover really a misplaced feel-good measure? I strongly suspect that all the scratching on the canopies at the school actually results from the covers constantly moving over the plexiglass surface. If you just leave your canopy uncovered, is it likely to be damaged by the elements??
Basically, it would be a heck of a lot more convenient for me to operate out of CYOW, but if my plane really would be much better off in a hangar, perhaps I should sacrifice convenience and go to Carp.
Thoughts?
Thoughts?
