bizpilot
Member
Anybody install a Titan IO 340, in a RV9or 9A? If so could you use the Vans firewall forward kit for the IO 320 to install it?
Bob Bisbee
1/2 owner of RV14A
Yup, have a io-340 in my 9a, 230 hours in the past ~9 months, great power plant. Dual pmag, AFP, etc. I used the stock vans ff-fwd kit and it worked fine other than the throttle/mixture bracket which did not fit. I ended up using the AFP bracket base with some custom-made steel offsets.
https://photos.app.goo.gl/kUZBNnjd6AA7bsgx8
Titan just shipped my 340 today, obviously not installed yet but everything I have ordered is 320 based since the engine is externally the same size.
I have an OX-340 on my -9A and used the standard O-320 baffle & FWF kit without any problems. I had to make a new FAB as the Rotec TBI is shorter than a standard carb, but that is the only difference.
