Drill a 1" diameter hole and use these doors:
http://m.aircraftspruce.com/catalog/hapages/accessdoors.php
I use them on all 3 fairings, as well as the valve stem extension on AircraftExtras.com.
Use a laser pointer of some kind. Block or jack up the plane with the pants off. Then, set a laser pointer at the valve stem and put the pants on. The laser will still be pointing at the valve stem.
I drilled holes in my wheel pants for using an extension to check pressures and then, 3 or 4 years later, I replaced the tubes and tires and guess what? The new tubes have stems that point in a way different direction and nothing lines up anymore.
The old tubes and the new tubes were the same manufacturer part number bought from Van's.
Now I have useless holes in my wheel fairings. Not a big deal, but heck.![]()
