I simply wrap a strap around the engine mount, hook up to the engine hoist and lift.
I made my own wing jacks out of found items. One hydrolic jack and one screw jack. Both were built up to the right highth with wooden a-frames made from scrap lumber and drywall screws. They lift at the tie down like the real thing only I dont have to remove the tie down 'cause I made a slot to hold the rings. By the way, I've found that airport dumpsters are the most fruitfull providers for the avid diver.
I use this jack. Kinda pricey but like everything else in life, you get what you pay for. It is very easy to use, requires no modification to the wheel nut, assembles and breaks down quickly and is stored in a small cloth sack.For those with finished planes, how do you do tire changes? Do you put a regular jack somewhere under the axle and jack up one side at a time?
Don't think this method would work as well for the "A" models.
An idea I got from a local builder was the following. Get a short (1 foot) section of steel rod about 3/4 to 7/8 inches in diameter. Take the axle nut off, and slide this steel rod into the axle, with enough sticking out that you can get a jack under it. Then jack up by this steel rod, and then put wooden blocks under the axle on the other (back) side of the wheel. With these wooden blocks supporting the axle, you can remove the jack and slide the wheel off.
Anybody else tried this approach?
This method works very well for the RV-8. I recently used it on my condition inspection.
When you take the weight off the wheels on an RV-8, the wheels move inboard -- quite a bit. Because of this movement, I'm not sure how well the various methods of jacking near the wheels would work on a -8. Although I've never tried it, I would think the gear legs would start to move as soon as the friction between the tire and the ground was reduced. A steel rod through the axle might allow the gear to move inboard and potentially topple the jack.
The gear legs of an RV-6 move inboard as well, though not more than an inch or so. But I always use a floor jack with rollers under the Avery RV jack to keep everything safely aligned. A bottle jack as shown in the photo would be a little too sporty for me.![]()
Don't think this method would work as well for the "A" models, though I suppose you could put a sawhorse under the tail or something.
Sure, the -8, especially fitted with Grove Gear is a slightly different animal. I find the "Handy Jack" works especially well. Inboard movement of the wheel as weight is removed is minor and within seconds, the tire is clear of the ground and can then be removed from the axle without any wheel nut modification. The Handy Jack is said to work well on tubular gear and the link provided is illustrated with photos demonstrating the lifting process on an RV-6......When you take the weight off the wheels on an RV-8, the wheels move inboard -- quite a bit. Because of this movement, I'm not sure how well the various methods of jacking near the wheels would work on a -8.........
I find this way to be a safe way to service the wheels. Remove the nut, slide in the rod, jack it up, slide the wheel onto the rod, place a wooden block under the axle right where the wheel was, let down the jack to set the axle on the block. Remove the jack and slide out the wheel.
When jacking the aircraft by the axle with a rod in the axle, you never remove the weight of the aircraft from the axle, therefore the wheel / axle does not move in as it would if you lifted the weight of the aircraft by the motor mount or the wings.
I don't understand why modifying the axle nut would be required. Why not just remove the axle nut prior to jacking it up??
This is exactly what a local builder recommended to me. I picked up a 1 foot piece of cold-rolled steel rod for less than 10 bucks.
The nut is what keeps the wheel on the axle. When the nut is removed the wheel could slip out
...Never lift the airplane by the engine lifting eye...
The question of how to jack up an RV comes up regularly and it's a constant source of amusement to hear about the outrageous Rube Goldberg contraptions people come up with to avoid spending $100 for a wing jack to lift their $80K airplane. (Or even less, since you can buy a tall bottle jack from Harbor Freight for about $40 and make your own out of 2x4's and electrical conduit.)
I made a plate with 2in bushings and bolts to match the brake pins. I use a
low profile jack and insert the plate into the brake adaptor and jack the gear.
Works great and allows me to carry it onboard while not taking up any space.
Walt - RV-6A
