I'm having terrible grief with nailing the nose ribs to the main spar of my RV-8 wings.
So far, with the help of my brother we've managed to rivet the end ribs to the spar with not a huge degree of finesse, which is disappointing. We haven't even begun to attempt the "inner" ribs where the bucking bar is held at arms length through several lightening holes...
How are people doing this? There's nothing enlightening in the instructions and precious little in a VAF search. What am I doing wrong if noone else seems to be having issues with this?
Main issues are the amount of energy/time/pounding that's going into the rivets with very slow (and ultimately unsatisfactory) shop head formation. I'm doing this with the wing mounted conventionally in the frame and with the shop heads against the spar (i.e. rearwards) using a 1kg temporary bucking bar with a 470 die mounted in it and back riveting with the gun and back rivet set.
We can get the shop heads to form more quickly with increased gun pressure, but this dramatically increases the risk of the bucking bar bouncing off the other side.
I can't quite see how they can be rivetted the other way 'round since access to many of the manufactured heads from the rear of the spar with a universal rivet set would be impossible due to the proximity of some of the main ribs
What suggestions do you good folk have?
