I am at the point where I need to decide on a targa strip for my tip up (RV-9A), aft end of the front canopy. I may also put on a strip center top of the back window. I have reviewed old posts for glass techniques for the targa and a couple aluminum made ones. In terms of pros and cons with which direction to go, I see possible delamination of FG (happened on two folks), sanding mess, maybe longer time to fabricate? It seems the alum would be simple to template and build with 0.025 or 032 sheet, afix with existing screws, maybe every other hole if one doesn't mind the screws showing.
Any other pros and cons from those that have built them? As an aside, i have no glass experience, though will change soon with the canopy front edge fillet.
