Gents,
After many years on my RV-7A project I am days away from completion. The only thing left is dressing up some wires under the cowl and final assembly at the airport. All the fiberglass is pinhole free so I am really just about complete.
However I re-installed the tip-up canopy the other day and the side fit isn't as good as I recall when I built the canopy several years ago (rather embarrassing how long this project has taken). The fit I am referring to is the match between the fuselage side contour and the canopy frame side contour. For those tip-up builders, you know what I am talking about.
The pilot side is good with a slight .020" under-lap (the canopy frame side is inboard of the side of the fuselage). But the passenger side has about .060" under-lap which I am not happy with. Just to check I removed the gas springs to see if they were contributing to the problem,they weren't
I have a few choices:
1. Leave it and live with it. However it is rather noticeable.
2. Remove the screws holding the canopy on and try to bend the canopy frame. Rather risky with questionable results and damage to the painted (interior) frame.
3. Add fiberglass and filler to the outside of the canopy side skin. Low risk. Questionable cosmetic results, future cracking problems?
I recall when building the frame I wish I had a Stretcher/Shrinker to get the bow in the frame correct but after tweaking and twisting I thought I had it rather good. But after riveting the canopy side skins, installing the plexiglass, the fit did change (obviously).
Any input would be appreciated.
