Buggsy2
RV-9A with tip-up canopy. Following Vans instructions, I trimmed first around all the edges of the raw canopy removing obvious excess. Then trimmed further trying to get the forward edges to fit flush to the C-702 canopy skin. And again following instructions,
My question is, how much trimming and fitting should I continue to do? Right now, the forward edge of the canopy and the C-702 skin fit as follows: at the top (centerline of the canopy and +/- 3-4 inches each side of center) there is a 1/8" or 3/16" gap between canopy and skin. Moving away from center, they fit flush, both sides. Then moving yet further, halfway down each side, there is a gap again, 3-4 inches long, 1/8". This is with the canopy sides flattened against the frame.
The gaps are very easily closed with light pressure. Should I accept them as-is, and close them when the entire windscreen edge is fiberglassed/screwed to the C-702 canopy skin? Or should I continue trimming and fitting? I worry that if I continue trimming I will trim too far soon. I have at least 1" excess on the aft edge.
Gap around centerline, 1/8" to 3/16".
Gap partway between center and side, 1/8".
I got reasonably close and made The Big Cut last Sunday.When you have gotten the fit to be somewhat close (it doesn't need to be perfect: it actually becomes much easier to deal with once the canopy is split)
