OK, so I have cut quite a bit of fiberglass in my RV ?career? so far ? trimming cowlings to fit for example. My usual tools are the cut-off wheel on a die grinder, and the 2? sanding disks on an angle die grinder ? they work quick, but do generate quite a bit of dust. I tried something new today - can?t remember where I saw a picture of someone using a set of shears to cut the excess flange off a cowling, but it was recent. I needed to do a little trimming on or pink cowl, so for an experiment, I picked up a pair of sheet metal shears, and nipped off a corner ? no cracks, perfect line, and easy to control. So I trimmed a whole bunch more ? boy, the lack of dust and noise was inspiring!
I still had to finish with a sanding block, and the parts of the cowl I was trimming were thin ? not sure how it would work on the thick stuff ? but add this little idea to your bag of tricks and give it a try the next time you need to trim some Van?s glass and the neighborhood noise curfew is in effect?.
Paul
Paul
