Michael Burbidge
I used glow sticks to help line up drilling holes in wheel pants with the holes in the brackets underneath.
Here's how I drilled the holes that the tow bar goes through.
Take one glow stick. Flex it until the contents are mixing and glowing. Then cut off both ends. The liquids doesn't flow out very fast.
Stand the hex bolt on the threaded end and fill the hole in the top with liquid from the glow stick.
Place scotch tape over the hole to keep the liquid in.
Screw the bolt into the nose wheel fork.
The fuller you can get the hole the better. You see mine isn't quite full. When I drilled the hole I compensated by drilling near the top of the glow circle.
Finally, put the wheel pant on and drill.
Worked pretty well. I figured out other ways to use the glowing liquid for some other holes, like putting it on a piece of paper and then taping the paper to the back of the bracket, so the glow shown through the hole in the bracket.
Michael-
![JOkRs1O.jpg](/community/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FJOkRs1O.jpg&hash=5f23131bb2e2849d01d677484b3a843f)
![q6JXSBz.jpg](/community/proxy.php?image=http%3A%2F%2Fi.imgur.com%2Fq6JXSBz.jpg&hash=f8729e758e886bebfded714c5aa61e7b)
![ozLde1a.jpg](/community/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FozLde1a.jpg&hash=21c201fa5378ec9b9021f6f15e3965ea)
![3Gdsrtl.jpg](/community/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F3Gdsrtl.jpg&hash=98c0ce541d7971b6d6184d063e050ad6)
![OIyFww2.jpg](/community/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FOIyFww2.jpg&hash=89da7d7ab16722df3ad9c898defdad4f)
Michael-
