burgessbuilderMO13
Active Member
Has anyone ever tried to apply window tint film to plexiglass. This would involve a single curve window, not a canopy.
Dale
Dale
It doesn't work like it does in cars - the plexi 'breathes', so moisture will eventually get under the tint and cause it to loosen up. I found that the static cling with small holes in it works better as a shade device.
If you want to tint the plexi, optometrists use Rit dye to make special tint lenses for glasses. You can call Becky at Airplane Plastics about this process.
