Mike Busch says its good for high performance engines. Says he wishes he could recommend it for certified stuff but can't. ...
Some RV guys bugged him for help with temps and that is what he said will help.
Glad he's finally showing an interest in experimentals.
I'm pretty sure Mr. Busch does NOT advocate advancing timing to help with temperature on experimentals. Increasing spark advance WILL cause higher cylinder head temps.
With that said, question for the OP:
You said older Monte Barrett engine. How many hours? Advanced timing could be an indicator of Mag wear.
Skylor
RV-8
On an older Monty Barrett IO-360 with 9.5 to 1 pistons, I am seeing both mags set at 26 to 27 degrees. One mag newer, one not.
Is this deliberate for more power, or just a mistake?
Bad for the engine?
Mark
Timing with high compression pistons, which you have, is generally set at 20 degrees (check the data plate).
I reset timing if 1-3 deg off spec. and will monitor it for change, more than that and the mag needs to come off IMO.
25 degrees on the data plate.
Two slick 4371 mags.
Any reason not to just call Barrett (BPE) and talk to them? Nice, helpful, knowledgable folks.
... what happens is if the point contacts wear faster than the point cam the timing retards, if the cam wears faster than the points the timing advances
I think you got that backwards Russ (easy to do). Point wear advances and cam wear retards is my understanding.
See paragraph on bumping the mag.
Yes you're right and I knew that but typed it out wrong, thanksI think you got that backwards Russ (easy to do). Point wear advances and cam wear retards is my understanding.
