Folks,
I am endeavouring to time the Hall Effect module on my Plasma plus II electronic ignition fitted to my nearly completed RV6, but am unable to get the green timing light to turn on when I rotate the module iaw the manual.
The module is installed on the RH mag location, engine is O-320, with an ignition switch.
two questions arise;
1. Presumably I should have the EI power on.
2. Presumably I should also have the Ignition switch ON.
3. The Manual states to rotate the module counter-clockwise. Is this as viewed from the front or rear (and does it really matter).
Any other suggestions highly appreciated thanks.
Graham Murphy
New Zealand.
Graham Murphy
New Zealand.
