Working in Section 15 (Rear Spar) right now. I built the four aileron hinge brackets (inboard and outboard) including the two from the SB 16-03-28.
When assembling them, the came together nicely and had no problem inserting the Com-3-5 bearings into the Aileron hinge brackets. Then I clecoed and riveted them together as instructed and there is no noticeable gaps between the bracket pieces.
I noticed that in two of the hinge brackets, the bearing swivel very easily. But in the other two, they are tight and do not swivel very easily. Is this a problem?
I sprayed some LPS2 and made no difference. I?m concerned this will create problems down the road for me as I?m a first time builder and not sure of the implications of those bearings feeling tight and not swiveling easily. I can get them to swivel if I insert a punch and move them, but they are not easily moveable by hand, unlike the other two.
Appreciate insights from those more experienced than I.
I looked for similar questions from others but couldn?t find anything.
