rv8or
Found the ideal way of making these home made nut plates.
I had a spare W731 wing tiedown bar extrusion, I cut two 1" lengths then drilled and tapped at 90 degree to the existing hole for the tiedown ring to screw into. Used the thin ears to rivet to the bracket behind the seat.
If you PM me I can send a photo.
Rob
RV3 G-BVDC
Very slow build RV8
Share in L4 Cub
Tiedown ring picture:
I have tiedown storage nuts just behind the rear seat, but ended up keeping the rings in the bag with the tiedowns. KISS
Simpler yet, I store my tie-downs in the little receptacles in the wings. They screw right in and that way I always know where they areā€¦
