Riveting the Tie-Wrap Clip to the rudder horn assembly and I'm not sure if I should drill out this pop rivet?
https://photos.app.goo.gl/Ld1N468PY4KTKCSw8
https://photos.app.goo.gl/SGLn6h97EkMh31bM6
Looking at it it looks like the manufactured head is dented/cracked (also I will be touching up with primer, I assembled too soon after priming... Don't worry
). Should I drill it out or just go with it? Not sure how big of a difference it will make as it's attached to the Tie-Wrap Clip. Thanks!
