Anybody come up with a cable mounting solution for the Thunderbolt IO 390 with Airflow Performance? Van's says for this combination "refer to the AP manual". Translation: "you're on your own, good luck".
I have an FM-200C airflow unit hanging on the Thunderbolt YIO-390-EXP243; the AP kit seems to be for the FM-150. Confirmation that somebody got this to work with the FM-200C on the new EXP engine?
So the FM-200 has throttle on one side and mixture on the other, and doesn't appear to be changeable due to the extra linkage on the throttle side. I got a message in to AP to see if they have anything that will work. If not, I suspect I'll just figure out and fab up a throttle bracket the 'normal' experimental way. I always like to see if anyone else invented my wheel first, though.
Thanks for the follow up on FM-200 throttle cable! Now if I could only get oneā¦. 15 months and counting on backorder (along with a bunch of other it,s mostly to do with exhaust) ��
