According to dwg 33, the engine is supposed to have 1.25 degree offset.
That translates to a bit more that 1/4" across the 13" spinner plate.
Looks like that is not built into the cowling. Mine is greenish fiberglass with visible honeycomb and no visible scribe lines.
So it looks like I need to build out the right side of the front of the cowling.
Which brings me to this question: What is the minimum distance between cowl and spinner you successfully have that still allows removal of cowling?
(Plans calls for 1/4", but I'd like to make that smaller.)
Finn
Finn
