pilot28906
I am connecting the throttle cable to the fuelservo arm per OP-22. I notice that there is only one 5702-75-60 washer called out at the rod end bearing and a standard washer on the other end. All of the other rod end bearings show a 5702 washer on each end. Is the print wrong or is there a reason to have only one at this rod end bearing? This is on a RV 7 with IO360-M1B.
