yankee-flyer
I'm about ready to skin the fuselage and remember quite a bit of discussion on a couple of points. I'd like to verify that I've remembered the consensus opinion correctly.
1) Spar slots in side skin should be cut about 1/8" wider (not taller??) than the instructions say, which would put the cuts outside of the punched holes.
2) do not install the top skin (turtledeck) when shown-- wait until all wiring (including control cables???) is in place.
3) There was quite a bit of discussion about putting shims under the ruddder pedals to allow clearance for wiring. How thick and where? Does anybody have a photo that they can post or send?
Thanks guys
Wayne 120241 N143WM
Thanks guys
Wayne 120241 N143WM
