Get it done and flying????
saw an rv8 somewhere that had piano hinge on both ends of the oil door. one end was the normal hinge. the other end had one part of the hinge riveted to the door and the other riveted to the cowl. with the door closed, one could slide the pin in from inside the forward bag area, holding the door shut, with no exterior fasteners. clean, light and easy. wish I'd seen it prior to drilling my door for the normal 1/4 turn closures.
Even on the shop floor in St. Louis where combat aircraft production was not too long ago the region's dominant employer, "platenut" and "nutplate" are interchangeable. That's Missouri for you. We can't even agree upon Missouree or Missourah as the correct pronunciation.......Sure, you can dimple the ears of a "flat" nutplate.....I've always called them nutplates. Is that a regional thing? Inquiring minds want to know...
Two mods that I did on my 9A:
1: Added a remote camera mount. Not your typical forward-looking camera, but a high-res digital camera (12 Mpxl) that is mounted in the bottom of the R wing. It is on a two-axis gimbal that allows it to swivel 30 degrees L/R and/or F/A, controllable from the cockpit. Camera (I use a Canon digital) goes in the box and outputs to a laptop in the cockpit (which also controls focus, zoom, etc.).
greg
If I counted all the nutplates I have ever installed it would easily number in the many thousands. If I restrict the discussion to RV's, it would include a few hundred platenuts and that includes among other things making all the floors removable with screws and nutplates. In no case have I ever installed or even felt the need to install a single dimpled platenut. I'm sure that is because (as my former employer almost always directed) I routinely use NAS1097 rivets to attach nutplates. On thin sheet thicknesses commonly used on RV's the NAS1097 rivet is ideally suited to attach platenuts.
EJ,Rick, does the dimpled sheet not cause the platenut to stand off ? Could you detail the sequence with the NAS rivets. Thanks
EJ,
In the post, I was referring to the type of platenut that requires you to dimple the 2 rivet attach holes, a type I have never felt any need to use:
Of course, when a sheet is dimpled so the screw is flush with the surface such as is used on inspection covers, I use K1100 (dimple) type platenuts. Sorry for the confusion.
I do try to be clear when explaining things and apparently fell short in this particular case. So let me try to explain it all a bit differently. Shown on the left is a part that has been dimpled to accept a total of six K1100 nutplates. Shown on the right is its mating cover. Notice the cover on the right has a series of 6 dimpled holes in it. That cover will accept flush head screws. Okay then, if you are not aware, a K1100 type nutplate is manufactured in such a way as to accept dimpled sheet while laying flush. I suspect this fact may be the source of confusion in some minds. Nevertheless, for illustration, see the smaller picture inserted into the larger picture with the arrow pointing towards it. This insert clearly shows rivet shop heads set into a K1100 nutplate sitting perfectly flush against its mating surface. Now the K1100 is attached just like most other nutplates...using two AD3 rivets. My original point was merely suggesting that NAS1097AD3 rivets are more suitable than AN426 rivets for attaching nutplates, any nutplates........ if you dimple the part to rivet the nutplate (USAF) to, the nutplate can't lay flat to the part.... at the rivets.
OVERSIZE SHANK RIVETS
These NAS1097 rivets feature a 1/8" diameter shank with a head size that of a 3/32" rivet. Perfect when rivet hole becomes enlarged requiring 1/8" shank but 3/32" head matches the rest of your 3/32" rivets. http://www.aircraftspruce.com/catalog/hapages/othersizerivets.php
