OK, there is no doubt in my mind that the RV line of experimental airplanes are the greatest thing to come along in general aviation since the Piper Cub?.but nothing is perfect! Here are a few little things we learn for ourselves (some the hard way?.) over time:
1) Those ?non-slip? wing walks with the ?RV-x? cut in them? They are as slippery as dog snot if the soles of your running shoes are wet!!
2) Putting the last gallon of gas in an RV tank takes patience as the fuel drains through the baffle holes
3) The grease fitting on the tail wheel? Pump as much as you want in to it ? it just fills up the wheel, and doesn?t lube the bearings! And makes a mess?..
I?m sure others can add more?.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
