LettersFromFlyoverCountry
I'm still not following why Doug's plane isn't in Texas and I've given up trying to figure it out -- it sounds like it's an inside joke of some sort -- but the fragmented messaging got me thinking -- Where's the worst place to build an RV? Where does a builder face the biggest challenge?
I've decided the worst place is Minnesota and/or the upper Midwest.
It's true, of course, that there are hotter places -- the desert southwest and Texas, for example. There might even be colder places.
But I can't imagine a place that has such extremes.
Last night I was out at the hangar working on the false floors, which-- of course -- requires lots of "under the panel" crawling.
Dewpoints are at record levels here. The temperature is in the 90s and there's no air under that panel. I have to bring three changes of clothing to the hangar every time I go there. The other night I fired up the compressor just to blow air on me to try to dry off between fittings. When I walk into the hangar under the not sun to open the door, I immediately flash back to scenes from Cool Hand Luke. "What we have, heeyuh, is a failyah ta communicate." It's a horrible, horrible experience, not far removed from the 2 minutes you spend in the PortaPotties at Oshkosh.
Meanwhile, in about four months, I'll be dressed in long underway, flannel jeans, sweatshirts, parka, and rabbit hat.... running between the part I'm working on, and the small propane heater in the unheated T-hangar to thaw my fingers out.
We might not be the best builders. But we're the toughest!
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Bring on winter!
![false_floors_aug4.jpg](/community/proxy.php?image=http%3A%2F%2F4.bp.blogspot.com%2F_nw6qmkwwuYE%2FTFlqyNaMjJI%2FAAAAAAAADAc%2Fw79_dFHv4tU%2Fs1600%2Ffalse_floors_aug4.jpg&hash=d3ff6b9d08b7d99679843f0f0b50c3a8)
Bring on winter!
