DeltaRomeo
doug reeves: unfluencer
Staff member
A nice lunch out at 52F Wednesday with some of the retired SWA pilots and mechanics. Four RVs in the background, deer chili, green chili stew, shrimp gumbo, key lime pie and cherry crumble. Not exactly the worse lunch, and GREAT conversation.
Hope you have a wonderful Thursday.
v/r,dr
dr (for a friend)
SingleTrax
RE: SL-00085 Flap Actuator Upgrade
…scsmith Q. Jonnyb A.
Is there an equivalent drawing for the RV-8? And I am puzzled by ATC_RV8OR's comment about it also being an aileron hinge?
Mothership
RE: Auxiliary power connection
…Richard Connell
I have an Anderson plug for each battery. 2 x PC680s.
Never needed to jump but I’m sure that one of those mini Li power packs would do it. The battery is only about 12” of 8AWG away.
I use these for charging rarely but quite often for hangar flying.
…John Retief
Here is what I came up, after careful consideration . I wanted access from outside the aircraft . It must be safe ,one can only imagine what will happen if the two poles touch each other in mid air ( the Anderson plug that some suggested is not safe according to me). So I decided on the plugs used on invertor welders which is widely available and cheap. The placing is just under the main solenoid. In the aircraft I only carry 2 short male leads, which can be connected to a charger or jumping cables. When not in use you push 2 rubber grommets into the holes. All comments welcome.
RE Wheelpants …DanH
Finish it all before you fly it. Everything. Even if it doesn't fly straight, diagnosis merely means removing the finished pants for one flight.
Fit the pants on the bench, early in the build, and you'll save a whole lot of crawling around.
OFF TOPIC:
